Rasterising Text and Pre Composing
Olly Lawer
on Mar 20, 2012 at 2:09:32 pm
I can't quite figure out what I have done wrong, but wondered if someone could help
I done exactly the same with two layers, but I am getting different results I can't figure out why.
1. I have a layer with an illustrator file in. I imported as comp. Opened comp. Rasterised layers. Brought into the main comp, but when I resized, I lost definition, so I precomposed and made sure the comp within the precomposition had rasterised layers turned on. Now when I scale up I keep definition. All fine.
2. I followed these exact same steps with another illustrator file (this time a set of 3 - although I pulled them out of the comp they were put into when AE imported them as I didn't want 3 of the files) - but when I increase the size, the image loses definition, unless I rasterise in the main comp.
At a loss.
Olly Lawer
Tudor "Ted" Jelescu
Re: Rasterising Text and Pre Composing
on Mar 20, 2012 at 2:15:46 pm
Post a screen shot of your layers and timeline.
Tudor "Ted" Jelescu
Senior VFX Artist
Olly Lawer
on Mar 20, 2012 at 2:24:18 pm
OK, will look to do that.
Just tested out with another layer and that one was fine also! Just the one set. I wonder if it's because the comp contains more than one layer?
Olly Lawer
Olly Lawer
on Mar 20, 2012 at 2:29:16 pm
Don't worry. Figured it out.
I didn't realise that if you want to scale up in the main comp, you have to rasterise the layer too. Solved by animating in the pre comp and then applying the transformations in the main comp. Transformations wouldn't work in the main comp if the layer was rasterised!
At least I found a workaround. Annoying tho.
Olly Lawer
Walter Soyka
on Mar 20, 2012 at 2:49:44 pm
[Olly Lawer] "I didn't realise that if you want to scale up in the main comp, you have to rasterise the layer too."
Just a little terminology correction: you are talking about "continuous rasterization." The vector art is continuously rasterized, so scaling it up doesn't cause image degradation. If it were merely rasterized (as would be the case if you don't enable continuous rasterization), then once you push its scale beyond 100%, the image will degrade because it is not resampling the vector art at the higher resolution.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Olly Lawer
on Mar 24, 2012 at 9:05:58 pm
Sorry...still getting to grips with the terminology.
I cheated in the end by creating another comp with just the layer I wanted to zoom into (a coffee mug in this case that was part of another comp). The new comp I made 1920x1080 in size and increased the coffee mug to the full comp size, turned on continuous rasterisation and then dropped that into the main comp with the original comp (lower resolution coffee cup with other layers). Then just resized the new higher sized comp with the coffee mug and laid over the lower quality coffee cup and reduced the opacity of the layer underneath when I got to the bit in the animation where I zoomed in.
This is no doubt a very messy way of doing things, but it did mean I didn't have to fuss about animating the coffee cup again with the new larger comp.
In future, I guess it is best to drop each layer into a separate new comp and make as large as I need to (preferably comp size) with the layer being comp size. Then nest each of those separate comps into a comp that I want for that particular set of animation then nest that comp into the main comp with all the other animated comps.
Or bring each comp (the separate illustrator files within the comps), animate, then pre-comp the lot to tidy up.
The reason for doing all this is that I understand that 3D space transformations don't affect continuously rasterised layers, but by making the illustrator files large and turning on continuous rasterisation within the comp, but when that comp is nested seems to solve this problem. I still have great quality and all of the ability to animate the nested, non continuously rasterised layer.
I guess asking the illustrator to create each illustration the full size of the comp I'm working to (in this case 1920x1080) would be a good start!
Happy for someone to tell me i'm doing it all wrong and there is a better way!
Olly Lawer
