Displacement Particle Effect Ideas
Mike Simpson
on Mar 15, 2012 at 7:27:09 pm
I am wondering if anybody knows how to create the effect seen the following YouTube video from 0:05 to 0:07
As you can see, it appears that certain pixels (or rows of pixels) are displaced to other locations creating sort of glitch effect.
LINK:
I suppose it would be possible to accomplish this using masks but that would be very difficult and time consuming.
Does anybody know an easier way?
Thanks in advance!
Mike Simpson
Re: Displacement Particle Effect Ideas
on Mar 17, 2012 at 3:05:55 am
I cannot thank you enough! I've literally looked for this effect for months!
Mike Simpson
on Mar 17, 2012 at 2:50:41 pm
In case anybody else decides to purchase the "Damage 2.5" Effect (The one stated above,) once you have installed it and entered the serial for registration, the plugin does not react to the serial and the watermark does not go away.
I was able to remove the watermark when I entered the serial (still no confirmation of it's registration,) then I closed After Effects. Now make sure the open After Effects "As an Administrator" (Right click and choose 'Run as Administrator')
For some reason, the plugin still thinks it is the Demo version until you open AE as an Administrator.
Good luck to all future users!
