Denoiser 2 doesn`t work with large files.
Frank Brown
on Mar 15, 2012 at 5:59:43 pm
After Applying it to 4min footage it displays Draft Mode near the Frame Sample and do not Reduction.
Show Noise Detection works fine. Any thought why that happen and any solution?
P.S. yeah, I`ve played with sliders and tried to add Noise Reduction up to 300%, but it didn`t work.
Picture was the same as the original.
Dave Dunbar
Re: Denoiser 2 doesn`t work with large files.
on May 9, 2012 at 8:56:22 am
Denoiser 2 goes into draft mode when the quality of the comp is set to something other than 'Full'. Hope this helps
