After Effects CS5 project will not open...
Ryan Monroe
on Mar 14, 2012 at 3:04:12 pm
So, I have my after effects cs5 project and when I try to open it, it gets stuck on 79% and freezes.
I then moved a duplicate of the project out of the current folder and like I assumed the project did open and of course all of the links were broken.
I assume this means one of my links has become corrupted. Links being AI, PSD, MOV, JPG, FCP files and so on.
Is there a way to find out which link/file is the corrupted link/file or a way to fix the corruption?
I am not new to AE so my project files/folders set up is fine and I am aware of the problems with bad set-ups and poor management of files. Therefore, I am not entirely sure how what ever file(s) have become corrupt. Possibly during a duplication of the file to be used for another project? I don't know.
Any help would be great, thanks.
Walter Soyka
Re: After Effects CS5 project will not open...
on Mar 14, 2012 at 4:39:24 pm
You might try importing the project into a new, blank project instead of opening it.
You could try opening the files in their native apps and see if Illustrator or Photoshop chokes opening a specific file.
Alternately, you might try to narrow down the file by removing only one file type at a time from its current path until you can open successfully. Once you narrow it down by file type, you could isolate the specific file manually with a binary search [link] -- essentially adding and removing files from the search path by half until you find the one file that crashes the system.
Add 50% of the suspect file type back into the search path; if it crashes, remove half those files to get to 25% of the total. If it doesn't crash, add half back to the total to get to 75% percent. Repeat until you isolate the file causing the crash.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Ryan Monroe
on Mar 21, 2012 at 6:07:53 pm
Thanks Walter.
I had my graphics in folders according to type so it was easy to pull out folders/gfx until I found the problematic files.
I then replaced the files with different versions and now the project works.
Thanks again,
Ryan
