Problem with Text Quality
Terry Nutkins
on Mar 13, 2012 at 2:33:24 pm
Hi there,
I am using AECS4 and trying to create a title sequence in the 1080/25P preset.
Text layers look terrible: blocky, with jagged edges.
I have not had this problem before.
Any idea what caused be causing this and how I can rectify it?
John Cuevas
Re: Problem with Text Quality
on Mar 13, 2012 at 2:43:06 pm
When you say the text looks blocky are you talking about a rendered file or are you still in the composition window?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Terry Nutkins
on Mar 13, 2012 at 2:44:16 pm
Hi John - I'm still in the composoition window. thanks...
Dave LaRonde
on Mar 13, 2012 at 3:14:45 pm
You need to learn about the Pixel Aspect Ratio Compensation toggle switch at the bottom of the comp window. It looks like an arrow with heads at both ends.
Toggled one way the comp is 4x3 & squeezed horizontally, and the edges of the text look nice and smooth.
Toggled the other way the comp is 16x9, but the edges of the text look jagged.
When rendered, the edges are nice and smooth, no matter what.
Dave LaRonde
Sr. Promotion Producer
Erik Waluska
on Mar 13, 2012 at 2:48:32 pm
Check that the quality switch is set to full quality and that your comp window is set to full quality and 100% zoom. Is the problem just with a certain font? Does it still occur in other comps, other projects, etc.?
Todd Kopriva
on Mar 14, 2012 at 11:01:41 pm
Please post a screenshot of your Composition panel.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
