Unknown Exception AE CS5.5
Jan Van den Bossche
on Mar 6, 2012 at 9:09:13 pm
I run CS5.5 on a iMac OS10.7.3 3,4GHz i7 16GB Ram.
When I start CS5.5 I get the AE Warning: "Unknown Exception", when I click "OK" AE starts up and works fine but it's not really handy. I checked the forum and tried out everything...
The warning appears when the startup session is checking : "scanning folder: file formats - camera raw".
I also have AECS4 installed an PSCS4.
thanks,
Jan
Jan Van den Bossche
aaron spears
Re: Unknown Exception AE CS5.5
on Aug 2, 2012 at 7:49:29 pm
I'm having the same problem...did you ever resolve the issue??
Jan Van den Bossche
on Aug 3, 2012 at 7:23:18 am
Hi Aaron,
no solution...
I'm just rendering without audio and then I put the audio file under the video in FCP and export again, double work and double files but the only solution...
Jan
Jan Van den Bossche
