Batch Time Remap script?
Kevin Reiner
on Mar 3, 2012 at 4:55:08 pm
Anyone know of a batch timeremapping script. I have about 500 movies for a live event project. There may come a time where the director says make those 40 videos 20% faster, and those 30 videos 15% faster etc.
So I plan to use AE to do the time remapping. I'm going to make a clean AE project, bring in the files, make a comp for each file, time remapping each file to "X"percent, rendering out at new length with a file name with a identifying suffix added (ie BlueMoon_20slower.mov).
A script would help tremendously here, but I have been unable to find one and I am scripting illiterate. Or is there a compression tool that would handle this better? I've found that AE with pixel motion suits my needs.
Thanks for any help.
-Kevin
Mac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23" flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460
SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
Roland R. Kahlenberg
Re: Batch Time Remap script?
on Mar 5, 2012 at 2:01:16 am
Not that I know of but you can link Timewarp's Speed parameter to an Expression Slider. The tricky part is knowing how to group your clips in the timelines. Otherwise, all the clips will be affected by the speed property in similar fashion.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Kevin Reiner
on Mar 5, 2012 at 2:47:56 pm
Thanks Roland,
I was going down the same path as you suggested. I can control the speed of the clips in their precomps with a slider effect in a separate control comp. The problem then is rendering out each clip at its new length. I still have to manually set that. Not sure if there is a way to automate comp length to match new clip length.
-Kevin
32GB Memory
ATI Radeon HD 5770
Rourke 16 TB
Flanders 2460
SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
