need to create a goopy chocolate wipe
Heather Crank
on Feb 29, 2012 at 11:28:36 pm
I need to create some liquid chocolate that wipes across the page in a drippy goopy way...think oozzzing chocolate...has anyone ever done this? Did you use ae and a plug in or did you use a 3-d program?
Right now I have something using fractal noise and masks, but it looks more that a satiny fabric instead of goopy. Anyone have any suggestions?
H
Erik Waluska
Re: need to create a goopy chocolate wipe
on Mar 1, 2012 at 1:20:13 am
Here's a tutorial about making the fractal noise look like liquid that might help.
Heather Crank
on Mar 1, 2012 at 4:05:08 pm
Thanks...that's what I've got going now, but need it to be more gooey....I'll keep trying!
Kevin Camp
on Mar 1, 2012 at 5:54:00 am
Take a look at cc mr mercury or cc glue gun applied to a chocolate brown layer.
Also a drippy mask with cc glass may start getting close. You may need to apply cc glass as an adjustment layer, I'm not sure it sees the mask as a layer's alpha if applied directly.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Heather Crank
on Mar 1, 2012 at 4:05:42 pm
Thanks Kevin, great suggestions, I'll give them a shot!
John Cuevas
on Mar 1, 2012 at 3:28:53 pm
You might want to take a look at this tutorial using Freeform to create a waterbox, you probably could adapt it to your needs:
http://ae.tutsplus.com/tutorials/motion-graphics/create-a-water-box-using-s...
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Heather Crank
on Mar 1, 2012 at 4:06:10 pm
ooohh, thanks, this may do the trick!
