particular ( falling rose ) in 3d space
omid abesta
on Feb 27, 2012 at 12:58:59 am
hello
I wanted to make Particle (particular) in order to i have falling CALYCLE ( like red rose)
i made a 3d CALYCLE in after by effect:digieffects free form
( i wanted to use a 3d calycle photoshop but i did not find it)
by useing particular and such setting as
particle type: Sprite and its layer: my composition ( 3d calycle)
because i wanted my particles fall around my character i had to set
obscuration layer: my character' layer (choromaki)
now i want to help me
1- did i go process true?
2- i have a problem. 3d calycle layer, crosses my character' layer
3- can you introduce a tutorial about this
3- can you get me (or introduce) a 3d calycle PSD or 3ds that i can import it to AE insteat of useing free form
please see my clip to understand my project & problem better
http://www.4shared.com/video/KoEtYQzB/3d_rose.html
(i only placed a gray solid instead of my character. at first second 3d calycle crosses solid layer and then vanish)
omid abesta
Re: particular ( falling rose ) in 3d space
on Feb 27, 2012 at 1:56:52 pm
i still have the problem
my 3d particles crosses with obscuration layer and cause bad effect
when my 3d particles is in behind it =>is ok
when my 3d particles is in front of it => is ok
but when they exactly crosses eachother in not ok
Andrew Somers
on Feb 28, 2012 at 9:21:09 am
he obscuration layer is more of a convenience - but is not the best solution in all cases.
In YOUR case, use TWO separate layers of Particular, one for front and one for back.
omid abesta
on Feb 29, 2012 at 9:45:13 am
thank you
good luck
Chris Bobotis
on Mar 31, 2012 at 4:32:08 am
Nice use of FreeForm. Please show us the final clip when you are done
Cheers,
Chris
mettle.com
