parent to null but update position date
Justin Young
on Feb 18, 2012 at 5:54:34 am
I have a layer that's parented to a null. It used to be (or least I think it did) that when you parented a layer to a null and moved the null, the position values of the child changed as well.
How do I set things so that if I use a beam effect I can make it line up with the position of my child layer and still have my child layer parented to a null that's moving around everything?
Roland R. Kahlenberg
Re: parent to null but update position date
on Feb 18, 2012 at 9:05:37 am
You'll need to look at Expressions, specifically, Layer Transformations. You will require 2 Null Layers, a child layer and a fourth layer to contain the Beam effect.
Create the parent/child relationship between one of the Nulls (Parent) and the ChildLayer. Then apply Beam to a Solid and set Length to 100%.
Then apply the following Expressions to the Solid with the Beam effect.
NOTE: I've named the Child Layer as, ChildLayer - make the necessary name change to the script to suit your naming convention.
Expression for Beam's Start Point:
thisComp.layer("Null 1").transform.position
Expression for Beam's End Point:
L=thisComp.layer("ChildLayer");
L.toComp(L.anchorPoint)
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
