Motion Tracking Question
Ionut Anton
on Feb 17, 2012 at 11:23:01 am
Hy guys,
I have i bit of a situation regarding an already tracked footage.
After i tracked the footage, i applied the data on a null layer.
After applying it i noticed some wrong tracking points, which i fixed.
How do i attach the corrected tracking data on the null layer (which already has the first set of tracking data), without having to analyze again?
Thank you in advance,
Toni
Frank Brown
Re: Motion Tracking Question
on Feb 17, 2012 at 2:48:01 pm
Select your Footage -> under "Tracker" panel choose your "Current Track" you want to fix->
-> on the time line go to points you want to fix -> fix values (re-edit positions) -> re-apply Tracker to the footage.
Ionut Anton
on Feb 19, 2012 at 9:33:09 pm
Thank you Frank
