After Effects CS5.5 compatible with Premiere CS5
Nathan Skillen
on Feb 11, 2012 at 11:35:03 pm
Hi, if I upgrade to After Effects CS5.5, will it still be compatible (dynamic link, copy & paste) with Premiere CS5? (not 5.5)
Nathan Skillen
Re: After Effects CS5.5 compatible with Premiere CS5
on Feb 12, 2012 at 12:10:51 am
Found the answer myself on the Adobe Forums = no :(
"If you already have a suite, then you upgrade the entire suite.
Dynamic Link only works between applications in the same suite."
http://forums.adobe.com/message/3657055#3657055
Michael Szalapski
on Feb 13, 2012 at 3:41:08 pm
You can still use the two programs together, just not with dynamic link. After Effects will still be able to import Premiere projects though and you can always render a lossless file out of AE to put into Premiere.
That's how I work anyway even though I have the suite. It's a holdover from when Dynamic Link was flaky, computers were slower, and deadlines had no time to wait for me to fix issues. :)
- The Great Szalam
