Rough edges with Frischluft Depth of Field
Guilherme Todorov
on Feb 1, 2012 at 8:05:08 pm
I am working for the first time with Depth passes, exporting from Cinema4D to After Effects, because I've been told that the built-in DOF from C4D sucks, and that Frischluft is the best solution for post-DOF.
So I decided to give it a try... I set up the cameras in C4D, exported the Depth passes, all good to go, but when I go to After Effects and do the magic, I get some REALLY bad rough edges on the objects that should be in-focus.
here is a pic of the issue: http://i.minus.com/iOE6dZL3ZqLAA.jpg
here is a pic of the Depth frame: http://i.minus.com/iP97qCHrTVyey.jpg
has anyone dealt with it before? I dont know what I am doing wrong, or why everyone does it so easy
thanks
mark jones
Re: Rough edges with Frischluft Depth of Field
on Jan 8, 2014 at 12:04:45 pm
Hi, did you ever find a solution to this problem??
thanks
