3D tracked footage + warp stabilizer = bad result
Juori Juones
on Jan 26, 2012 at 2:25:21 pm
Hi everyone... I've hit a brick wall with this one and can't figure it out myself.
I tracked some heli footage with Camera Tracker plugin in AFX. The footage is quite shaky but the tracking looks good enough.
The problem arises when I add Warp stabilizer. The footage gets stabilized but the 3D tracked layers look out of place in some areas. Is this a problem with Warp Stabilizer or am I doing something wrong?
I'd appreciate any help since I'm really stuck with this.
J.
Dave LaRonde
Re: 3D tracked footage + warp stabilizer = bad result
on Jan 26, 2012 at 4:00:29 pm
You're trying to do two things at once when you should only be doing one thing at once.
I personally would stabilize the footage first, render it to a lossless codec, reimport it, and THEN do the motion track.
Dave LaRonde
Sr. Promotion Producer
Juori Juones
on Jan 26, 2012 at 8:50:47 pm
My tracked footage is inside a composition with some 3D layers. I added warp stabilizer to the composition, not original footage. I'm afraid that if I track stabilized footage, I won't get correct result...
Dave LaRonde
on Jan 26, 2012 at 9:37:11 pm
Apparently then, you have a choice to make: stabilize first and THEN track, or continue to work as you are and settle for a lousy track.
Dave LaRonde
Juori Juones
on Jan 27, 2012 at 8:03:36 am
Okay will try, thanks for your input!
J.
