Adjustment Layer = Crash?
Ryan Brau
on Jan 14, 2012 at 5:44:58 pm
Whenever I add an adjustment layer into my comp, and then I change frames After Effects Crashes :( Any ideas?
Tudor "Ted" Jelescu
Re: Adjustment Layer = Crash?
on Jan 14, 2012 at 6:39:07 pm
Give us more info:
system specs
AE version
OS
screen grab of project
If Open GL is on- turn off.
Tudor "Ted" Jelescu
Senior VFX Artist
Ryan Brau
on Jan 14, 2012 at 11:59:01 pm
System Specs - i7 2600k , 8gb ram, 6870 2gb.
AE Version - CS5 is all I know
OS - Windows 64 bit
And I'm not sure what you mean by Open GL on or off.
And it crashes even if I don't have any effects on...
Erik Waluska
on Jan 15, 2012 at 12:52:25 am
Edit>Preferences>Previews
Uncheck "Enable OpenGL"
Is it only happening in one comp or does it still happen even if you create a new comp? How about in a new project?
Try trashing your preferences file too.
Tudor "Ted" Jelescu
on Jan 15, 2012 at 10:06:53 am
Post a screen capture of your project- maybe we can see something there.
You got your answer from Eric as far as OpenGL goes.
Did you try creating a new project and adding an adjustment layer to see if it crashes?
Tudor "Ted" Jelescu
Senior VFX Artist
Erik Waluska
on Jan 14, 2012 at 6:49:24 pm
Yeah, that's pretty vague. What effects do you have applied to the adjustment layer?
Thomas Bui
on May 29, 2017 at 1:29:01 pm
I know this post is from a while ago but I have the same problem.
My AE version if AE CC 2017.
Every time I try to add an adjustment layer, my AE immediately crashes... Any ideas?
