How to remove specific things from an image ? example inside
Eran Sandman
on Jan 12, 2012 at 3:44:19 pm
http://orangedotgreen.deviantart.com/art/Yellow-notebook-paper-110119273
I want to remove the top circles of the page, so when i put another background i can see it.
How can I do it?
Dave LaRonde
Re: How to remove specific things from an image ? example inside
on Jan 12, 2012 at 4:12:45 pm
That's a bit of work, but not tough at all in principle. You just have to mask out the edges of the image, then mask out each individual hole at the top, and you're done!
See? It's easy. Just time-consuming, that's all.
Dave LaRonde
Sr. Promotion Producer
Chris Buttacoli
on Jan 12, 2012 at 4:50:03 pm
You may even do this in photoshop first before bringing it into AE.
Jm Chadillon
on Jan 12, 2012 at 8:16:26 pm
if you want it to look good, photoshop it cut out the white in photoshop then export as PSD.
OR if you are strapped for time
in PS do a color selection on the yellow paper, adjust so you get your proper selection on the paper and make a new layer from selection, delete BG layer. export as psd and import into AE.
