Adobe After Effects Expression Forum -- Changing Text Caps to Lower Case
Conrad Browning
on Jan 11, 2012 at 8:28:01 pm
To change Caps in text to Lower Case, use the shortcut: Ctrl+Shift+K.
Rob Dahl
Re: Adobe After Effects Expression Forum -- Changing Text Caps to Lower Case
on Jan 11, 2012 at 9:48:15 pm
You should ask this in the After Effects Expression Forum.
But if you are asking how do to use an expression to change the Text (called source text) from one case to another via an expression script:
you will need to use the following line of code in an javascript if/then container:
text.sourceText.toLowerCase()
Rob Dahl
Transparent Alchemy
Boulder City, NV 89005
http://www.transparentalchemy.com
