CS5.5 Upgrade - 32 bit machine
gary dumill
on Jan 10, 2012 at 11:58:16 am
MacPro1,1
Dual-Core Intel Xeon
Number Of Processors: 2
Total Number Of Cores: 4
2.66 GHz
Memory: 8 GB
32 bit.
The machine is in need of an AE update. But I only have the option of upgrading to CS5.5 from the adobe site, which requires a 64 bit system. I'm having trouble finding an update to CS4.
I'm aware that when you purchase production premium of a PC, that you get a copy of CS4 to resolve this problem.
Is this also the case when it comes to upgrading only AE, to CS5.5 on a mac?
Or are there any other options to upgrade?
Thank you in advance..
Kind regards
Gary
Kevin Camp
Re: CS5.5 Upgrade - 32 bit machine
on Jan 10, 2012 at 4:10:58 pm
osx has a 64-bit kernel, so 64-bit should not be a problem. but you need to check the version of the os to make sure that is supported but cs5.5. i believe that cs5.5 works with leopard and up, but do double check that.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Kevin Camp
on Jan 10, 2012 at 5:11:37 pm
a definitive option is to download the trial of cs5.5 and see how it works on your machine.
i do think you'll want to get more ram.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
