Rendering NTSC HD as PAL
Dan Brazil
on Jan 9, 2012 at 8:04:25 pm
Hello,
I am working on a project for a large video wall in NTSC 29.97 fps Progressive with a canvas of 4092x1188. I had a clutch of video sources and I plumbed for 29.97 based on majority wins plus I wanted to achieve a smooth scroll of background animation.
Anyway I probably digress...I understand that to avoid Judder the playback device video card and refresh rate of the LCD/Plasma screens need to be taken into account. So I want/need to deliver a version of my file in PAL 25 fps and I am trying to work out the best approach. Trying to keep it simple...so will it suffice to simply change the render output settings to PAL 25fps? I am importing my composition into Adobe Media Encoder and outputting an H264.
If it helps, here are the words of wisdom from Scala - the software that will be running the show:
http://www.scala.com/support/enterprise-scala/technical-faqs/scala-player-5...
Any tips appreciated.
Mac Pro, 2x2.26 GHz Quad Core Intel Xeon, 8GB RAM
Kevin Camin
Re: Rendering NTSC HD as PAL
on Jan 10, 2012 at 2:06:41 pm
http://library.creativecow.net/articles/kramer_andrew/fps.php
Andrew Kramer has a nice tutorial on making this type of conversion with AE. It's a little bit of an involved process but he walks you through it.
Best regards,
Kevin Camin
Dan Brazil
on Jan 10, 2012 at 2:34:18 pm
Thanks Kevin - I'll check it out.
