Layer and visible position ???
gary Jarvis
on Jan 5, 2012 at 6:44:38 pm
I do not understand why, when I have one layer above the other the lower layer shows on top on my screen??
Dave LaRonde
Re: Layer and visible position ???
on Jan 5, 2012 at 7:09:24 pm
It would help to see the position property for the layers in question. That's the obvious potential problem.
I know it's off, but you also might want to move that layer above the camera layer; the camera should be the uppermost layer in the comp.
Dave LaRonde
Sr. Promotion Producer
gary Jarvis
on Jan 5, 2012 at 7:52:09 pm
Hi there Dave,
I have copied the properties of the layers of concern also, I moved the layers in concern above the camera, no change.
John Cuevas
on Jan 5, 2012 at 8:10:55 pm
If you are refering to layers 8 and 11. Layer 8 is at .7 Z, and 11 is at 0. In Z space as you progress in positive numbers the items will move away from you, negative numbers bring them closer.
Layer stack doesn't matter here, you have placed layer 8 behind layer 11, if you make layer 8's Z position 0. It should move in front of layer 11.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Dave LaRonde
on Jan 5, 2012 at 8:12:16 pm
Yup, just what I thought: the z-position isn't constant between layers. Fix it and the problem goes away.
Unless you have some overpowering reason not to do so, why don't you use good ol' 2D layers? No camera or lights necessary.
Dave LaRonde
gary Jarvis
on Jan 5, 2012 at 8:30:31 pm
Thanks guys,
I kinda thought it would be something logical and simplistic, funny thing is I did a quick on and off of the 3d in layer 8 and it worked also, but, I do understand the logic and have followed your direction.
Actually Dave I kinda need the lights as I am doing a traveling spot on the character.
John, I like your little bit of Edison logic even though I am more of a Tesla fan
