images disappearing from comps
Colin Kennedy
on Jan 4, 2012 at 8:20:46 pm
Im animating puppets in their own compositions and then bringing those compositions in to my main comp. But for some reason when I bring in the puppet comps in to the main comps, when I return to the puppet comp the image is missing. So I cant edit the puppets in their own comps, unless I take them out of the main comp. Does anyone know why this is happening. Hope this was clear, thanks.
Dave LaRonde
Re: images disappearing from comps
on Jan 4, 2012 at 10:07:32 pm
If you are doing the following:
  • Animating puppets in their own comps
  • Opening the Main Comp's timeline
  • FROM THE PROJECT WINDOW, dragging the puppet comps into the timeline of the main comp should be having zero problems.
If you're doing it any other way, you need to explain exactly what you're doing to aid in diagnosis.
Dave LaRonde
Sr. Promotion Producer
© 2018 All Rights Reserved
