Export problem!!!
Ben McIntyre
Export problem!!!
on Dec 31, 2011 at 3:29:23 am
Hi, when I try to export my video from after effects, the screen randomly goes a white/gray color over the image, I need help stopping this!
The render settings I'm using are: H.264, 1280x720p, 59.94fps.
Here is an example of the problem - http://gyazo.com/8a993bf99949fcf4db7ecb799a908fb6
- Ben.
John Cuevas
Re: Export problem!!!
on Dec 31, 2011 at 11:50:33 am
Few things you can try. Make a lossless animation(I prefer QT Animation) and then take that into media encoder and render to your final resolution. Encoder does multi-pass encoding so you should get a better final file.
If the first approach also gives you problems another way would be to make a tiff, pict or jpeg sequence. If it comes out okay, great, but if not - you can find the offending frames, locate the spot in the timeline and replace them using "cntl+alt + s".
Perhaps others here might have some insight on why your render is doing that, but I haven't seen that particular issue before.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Tudor "Ted" Jelescu
on Dec 31, 2011 at 12:58:56 pm
Are you using Time Remap on one or more of your layers?
Tudor "Ted" Jelescu
Senior VFX Artist
