Opening later projects in after effects cs5
Emil Borch Larsen
on Dec 20, 2011 at 9:59:56 am
hi there, im about to continue on a AE project but i cant seem to open it?
when i open the project this appears:
After Effects error: The file you are attempting to open was created with After Effects Version 10.5 (Macintosh 64) and cannot be opened with this version. See http://www.adobe.com/aftereffects for information on upgrading your software.
please can anyone help ?
Emil Borch Larsen - Part of JWT
Walter Soyka
Re: Opening later projects in after effects cs5
on Dec 20, 2011 at 3:30:41 pm
AE cannot open projects saved from newer versions.
New in AE CS5.5, however, is the ability to save down to an AE CS5 file.
Ask whoever sent you the file to open it themselves, then do File > Save as > Save a Copy as CS5. Of course, you won't be able to use any effects that are new in CS5.5 (like the Warp Stabilizer or improved camera DoF features).
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Linda Thompson
on Apr 20, 2013 at 12:25:19 pm
is there anything that can be done in CS5 or CS6 or above to enable the file to be opened in CS4 ? some kind of saving settings ?
I'm having the same problem. also specifying version 10.
I have either CS5.5 or CS6.6 (not sure, I can check) at the office and CS4 at home and want to open it at home.
Walter Soyka
on Apr 20, 2013 at 2:09:12 pm
[Linda Thompson] "is there anything that can be done in CS5 or CS6 or above to enable the file to be opened in CS4 ? some kind of saving settings ?"
Sadly not. CS6 can save down to CS5.5, and CS5.5 can save down to CS5, but that's it.
You might try pt_OpenSesame for interchanging between CS6 and CS4.
http://www.aescripts.com/pt_opensesame/
Walter Soyka
