Switching a layer to 3D suddenly causes it to blur
Soose Triolo
on Dec 19, 2011 at 8:37:37 pm
I'm creating a cloud of images that a camera travels through. When I added an image and turned it to a 3d layer, it suddenly blurred out. Out of the 60 other images in the comp, this is the only one. I've gone through the Material options to check on attributes and they're the same. The camera depth of field is roughly 600. Any ideas? Anyone? Thanks in advance...
Soose
Walter Soyka
Re: Switching a layer to 3D suddenly causes it to blur
on Dec 19, 2011 at 8:50:52 pm
If you disable the camera's DoF, does the blur go away? If so, then you should either adjust the layer's position or the DoF settings.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Steve Blacker
on Dec 19, 2011 at 11:20:31 pm
Is it possible that you have motion blur enabled for this layer only?
It's only work if you'd rather be doing something else...
