Align colors between footages
Romain Dreinal
on Dec 11, 2011 at 12:01:20 pm
I'm trying to merge 2 footages of the same scene. A first footage as layer 1, the second one at the layer 2, with a rectangle mask to merge only a part of the footage.
The merge is almost nicely done (because I was on a tripod and I didn't stop the camera between the 2 shots), but I still have a slight color difference so I'm able to see the rectangle of my mask on the final merged footage.
Is there a way to align color/white balance/luminosity so that my rectangle mask become invisible ?
Thank you !
Romain.
Brian Charles
Re: Align colors between footages
on Dec 11, 2011 at 3:57:31 pm
If the color difference is subtle a feather on the mask may fix the problem.
Otherwise you can color correct one side to match the other using Levels, Curves or Color Finesse.
Romain Dreinal
on Dec 11, 2011 at 6:33:23 pm
Thank you for your answer.
I succeed with the mask feather and a little bit of color correction :)
