No real time RAM Preview
Larry Andersen
on Dec 9, 2011 at 3:01:55 pm
No matter the size or complexity of the comp (320x240 with a solid position move only for instance, runs at 13fps in 30 fps comp), I do not get realtime playback in RAM previews. It's making me a little crazy. Relevant bits:
- MacPro Dual Quad Core 2.66 GHz
- ATI Radeon HD 4870
- AJA Kona 3 - though I'm just previewing through my Apple Cinema 24" displays
- 4 slot eSata card and ATTO Fibre channel cards also on board.
- The hardware configuration has not changed in a couple years.
- Running CS5.5 Production Premium
- I had intermittent similar issues while running CS5
- FCS runs fine.
- All prefs were trashed, no effect.
- I've been through all of the possible processor, open GL, and adaptive res combos as suggested on the Cow and elsewhere. No effect.
- Card config, top to bottom: AJA, eSata, Fibre, Empty, graphics
Any thoughts...please?
Larry
Larry Andersen
Re: No real time RAM Preview
on Dec 9, 2011 at 3:38:29 pm
...and 16 Gig RAM.
Kevin Camp
on Dec 9, 2011 at 4:07:22 pm
the problem is most likely the aja card or software.
if you installed the aja plugins for ae, uninstall them. i also remember that they used to recommend installing the 'ndd' version (the version that won't give the extra desktop monitor) for mac.
i'd also double check the slot assignment for your mac. if you can't find documentation, just send aja support an email, they've been quick with replies when i've had questions.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Larry Andersen
on Dec 9, 2011 at 4:25:25 pm
Digging deeper, I found a post that suggested updating the AJA Kona Software. I switched to version 10.0.1 and everything is suddenly better. I hope this helps someone else.
Best,
Larry
