I'm looking for "Tags cloud" effect
Santiago Escudero
on Dec 7, 2011 at 10:38:06 am
Hi, I'm trying to do something like that
I don't know if there are some plugin to do that, I try to do with expression but I don't have enough experience. I need the project can change ease the contents and object movement.
Like I said, I tried to do a sphere and link text to that object, but I don't get the result that I want.
If someone have any idea, I would be very grateful.
I thinking if is better to do this in other soft like Smoke, because it works in 3D space; making first the sphere in Maya and export like FBX. Maybe this way works best for what I want.
I await your answer, thanks.
Brian Charles
Re: I'm looking for "Tags cloud" effect
on Dec 7, 2011 at 3:24:55 pm
You could create the sphere from 3D text layers, parent them to a null and have them auto orient to the camera.
See: 3378_textsphere.aep.zip
Kevin Camp
on Dec 7, 2011 at 3:41:53 pm
if you wanted an easy way to get the words arranged in a sphere, you might look at these scripts:
http://aescripts.com/create3dshapes/
you'd also need to set the layers to auto orient to the camera, as brian mentions.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Santiago Escudero
on Dec 7, 2011 at 3:42:47 pm
Thank's, that's exactly what I'm looking for.
