High resolution 12960 * 1920
Bang Tran
on Dec 1, 2011 at 8:58:43 pm
Hi all. I'm new to AE and any help will be help. I will soon be creating content for a 12960 * 1920 video wall. I created a new compostion in AE CS5 that is the above size. When I export it to Premiere I don't know how to set the resolution to 12960 * 1920 for the prremiere project. Is it posible to do that with premiere of am I out of luck? Any help will be greatly apprciated.
Walter Soyka
Re: High resolution 12960 * 1920
on Dec 1, 2011 at 9:23:26 pm
[Bang Tran] "I'm new to AE and any help will be help. I will soon be creating content for a 12960 * 1920 video wall. I created a new compostion in AE CS5 that is the above size. When I export it to Premiere I don't know how to set the resolution to 12960 * 1920 for the prremiere project. Is it posible to do that with premiere of am I out of luck? Any help will be greatly apprciated."
Premiere Pro's maximum sequence frame size in pixels is 10,240×8,192. Your AE comp is too wide to fit natively.
When working on large-format systems such as this, it's critical that you understand what your deliverable for playback will actually be before you begin work. Very few systems like this actually take in a single file; most require pre-split media for display.
This will not be an ideal project to learn After Effects with. Workflows for projects like this are not necessarily straightforward, and the massive frame sizes are very demanding on system resources.
Since you're new to After Effects, I'd recommend the following link, in which Adobe's Todd Kopriva pulls together some important introductory materials:
http://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after-eff.h...
I especially recommend the Video Copilot "Basic Training" series that Todd links to.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Bang Tran
on Dec 1, 2011 at 9:29:00 pm
Thank you
Bang Tran
on Dec 5, 2011 at 4:48:38 pm
Walter thanks for the links they were the best i've seen so far. I'm a little confused about what you said "what your deliverable for playback will actually be before you begin work." Can you tell what you mean when you say deliverable for playback? Is this the type of file it will be, and what will be playing the file?
Michael Szalapski
on Dec 6, 2011 at 8:00:57 pm
Deliverable would refer to the file's format, codecs, and how many files it will be. As Walter mentioned, this sort of thing usually involves multiple files.
- The Great Szalam
