evenly spacing 50 shape layers for horizontal bar graph with expression?
Jason Kapell
on Nov 30, 2011 at 8:08:09 pm
This is probably a block head question. I am making a horizontal bar graph that animates from left to right. There are 50 bars that arrive at the center of the comp 3 frames behind each other. A camera (with null) dolly's along with the bars and rests when the bars rest. Anyway, I only want to duplicate the first bar so that each consecutive bar is evenly spaced (in y) from the one above. Is there an expression for this? I've searched high and low. Right now, I'm doing it manually. It's not only tedious, it's not working. I have the camera pull out and the lack of uniform spacing is evident...tons of flickering black lines.
J
Brian Charles
Re: evenly spacing 50 shape layers for horizontal bar graph with expression?
on Nov 30, 2011 at 8:27:28 pm
See the following.
Just duplicate the layers below as their X position references the layer above.
3347_offsetcontrol.aep.zip
