Optimizing Network
Luke Reed
Optimizing Network
on Nov 30, 2011 at 6:31:32 pm
Hello-
Problem:
Operating our small production company entirely across a local network has worked flawlessly for the last couple years. Recently, as we continue to grow, I have found the network has started to slow down- clearly understandable. I am now trying to increase our network speed and looking for any suggestions.
Background:
Our company specifically creates 5-30min flv videos with final resolution of 640x360. We shoot on Sony HDV cams at 1440x1080 , capture through firewire with CS5 Premiere and then create videos in CS5 AE with work comps 640x360. We have around 10 workstations operating windows 7 each with their own gigabit connection. We work entirely across a network share located on a windows sbs 2008 all connected over a gigabit switch. I understand working over a network is unconventional workflow but is necessary because of our short deadlines, numerous client revisions and multiple editors working on each project- Version control on individual machines would be next to impossible.
One suggestion I came across was using an iscsi san for all of the video files, with the san and the designers hooked up to a dedicated managed switch. Thoughts?
Thanks for you time-Luke
Dave LaRonde
Re: Optimizing Network
on Nov 30, 2011 at 7:01:14 pm
I can't speak to the issue of a speedier network. But I can tell you that you've temporarily painted yourself into a corner as far as Adobe software upgrades are concerned.
There are known issues with AE 10.5 rendering over a network: rendered files are often incomplete, and don't play back properly. It doesn't happen when files are rendered to local drives.
Adobe says it's working on a fix, but so far there hasn't been any progress as far as I know. So if you were looking forward to using Warp Stabilizer to help fix the occasional unsteady shot, you might want to temporarily reconsider upgrading.
Dave LaRonde
Sr. Promotion Producer
Luke Reed
on Nov 30, 2011 at 10:49:19 pm
Initially we were concerned with the the quicktime render errors that I saw associated with CS5. Ironically none of the described errors I've read have given us any problems. I render probably 5-10 different .movs a day across our network. I also have 3 render machines that work across the network. I'm staying clear of 10.5 and hoping the next full version fixes the issues.Knock on wood I suppose. Thanks for your help.
Walter Soyka
on Nov 30, 2011 at 9:17:31 pm
Working with video over gigabit Ethernet is much more common now that you might think.
Go ask this question in the SAN - Storage Area Networks forum [link]. Be prepared to get yelled at a bit by Bob Zelin -- but take his advice, because he is a genius.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
