make 8mm film scratches from white to black???
Julius Valentinas
on Nov 30, 2011 at 3:46:00 pm
Hi, I have some scanned 8mm film, the scratches are white and I wonder is it possible to make them black, that would allow further post processing in removing them. Also black seems less distracting to the eyes.
Perhaps there is virtualdub filer etc.
Thank you.
Luke Hale
Re: make 8mm film scratches from white to black???
on Nov 30, 2011 at 4:12:11 pm
I have had the same question in the past. I have transferred thousands of feet of 8mm film and in the end I decided that great color correction goes along way. Anything more detailed seems to take more time than it is worth.
( I also find it odd you have white scratches, usually they are black)
I will check back to see if anyone knows of a plugin, but it has been my experience that all the plugins make perfectly good video look like 8mm film not the other way around.
Luke Hale
Producer/Editor BYU-I and Department of Energy
opticalsmarts.com (Just for fun)
Walter Soyka
on Nov 30, 2011 at 4:22:34 pm
If you're talking about straight-line scratches, you could use the CC Simple Wire Removal effect to remove them.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
steve agriosi
on Nov 30, 2011 at 6:54:41 pm
Since FilmFix for AE By RedGiant is no longer available,
I'd recommend you to take a look at Freddy's Van de Putte vimeo page
http://vimeo.com/user678523
scripts and more here:
http://forum.doom9.org/showthread.php?t=144271
http://www.super-8.be/s8_Eindex.htm
Freddy Van de Putte is a master of scanning and cleaning up 8mm film using the freeware
AviSynth Application.
Freddy also wrote the most powerful scripts for AviSynth so he gets excellent results!
But If you have a strong budget and you don't want to spend your time on AviSynth,
there is the Foundry plugin Suite for Nuke / shake /Autodesk /fusion.
Furnace Scratch Repair
Furnace Dirt Removal
Furnace Motion Smooth
All you need!
cheers
