Using external audio and image
Rene Hansen
on Nov 20, 2011 at 3:46:45 pm
Hello
Is it possible to use external audio and images in After Effects?
Just like $.evalFile() to get text from text file.
So before I can use aerender.exe I can just change some paths in an text file and then audio aand images gets imported on the fly.
Erik Waluska
Re: Using external audio and image
on Nov 20, 2011 at 6:51:07 pm
Check out CompsFromSpreadsheet at aescripts.com. I've used it on a couple of projects and it works great. Just be sure the filenames and everything are spelled exactly the same as they are in the spreadsheet or it will give you errors.
Rene Hansen
on Nov 21, 2011 at 1:24:21 pm
Thanks. I have now tried that.
It requires for me to open After Effects and run the script. So I can't it as automated as I would like.
Other ideas? :-)
Erik Waluska
on Nov 21, 2011 at 4:06:26 pm
I guess I don't understand what you are trying to do. I don't know much about scripting. Sorry I couldn't be more help.
Romain Batard
on Feb 13, 2012 at 2:33:31 pm
Hey,
I have the same needs, did you finally find a way to do it ?
Thanks a lot !
