Synchronizing music to video in after effects
ellie zenhari
on Nov 18, 2011 at 7:19:15 pm
Hello everyone,
I am trying to synchronize a radiohead music to a video animation that I made in after effects, so the animation changes in rhythm with the music.. It is the first video and it would be for a personal project. Can it be done?
http://elliezenhari.com/motion2.html
Thank you in advance for all your help on this :)
Ellie
ginger
Tudor "Ted" Jelescu
Re: Synchronizing music to video in after effects
on Nov 18, 2011 at 7:44:06 pm
Sure it can be done.
There are a few ways to go about it.
It depends a lot on the kind of animation you want to do.
You can play the audio only by hitting the "." key on the numeric pad on your keyboard. Then you can set markers for the beat and changes in music by hitting the "*" on the numeric pad. Once you have these markers you can set your keyframes based on them.
Another way is to convert audio to keyframes:
http://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c11...
If you have Red Giant Trapcode Sound Keys, you can extract keyframes using amplitude or frequency ranges.
http://www.redgiantsoftware.com/products/all/trapcode-sound-keys/
Tudor "Ted" Jelescu
Senior VFX Artist
John Cuevas
on Nov 18, 2011 at 7:44:16 pm
It can be done. Trapcode makes a plugin called soundkeys that analyzes the audio spectrum and then allows you to select portions to convert to keyframes. The demo version only will do 300 keyframes per AE session, but you could open/close/open/close AE until you had an entire song if you were so inclined.
Also check the animation pulldown > Keyframe Assistant > Convert Audio to Keyframes. It's not as good as soundkeys, but will create keyframes based on volume...that might be good enough to drive your animation.
ETA: "Ted" Jelescu apparently can type a lot faster than me.
Johnny Cuevas, Editor
Walter Soyka
on Nov 18, 2011 at 8:10:06 pm
Two other sound-related tips:
Select your sound layer and tap LL (the L key twice) to reveal its waveform.
Hold Ctrl (or Cmd on a Mac) to scrub audio while scrubbing the CTI on the timeline.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
peter mcauley
on Nov 22, 2011 at 3:31:24 pm
And yet another option, this time from from Boris FX, is the BCC Beat Reactor, which can be used to convert audio waveforms into keyframes in the AE timeline. The free trial will enable you to work with the plug-in for a full 2 weeks without commitment or restrictions of any kind.
You can download it here: borisfx.com/downloads
Cheers,
Peter.
