Concentric squares
Putopian vohra
Concentric squares
on Nov 16, 2011 at 7:19:24 am
Hello all
This is my first post in this forum.
I have two doubts.
1) How can I create concentric squares with animation like this
2) How can I create a perfect circle/square in a comp with a non-square pixel aspect ration? Even when I press shift while creating the path, it appears stretched.
Putopian
Brian Charles
Re: Concentric squares
on Nov 16, 2011 at 3:51:29 pm
Use Radio Waves (Effects >Generate>Radio Waves) and set the shape to a 4 sided polygon then rotate it 90 degrees.
You can animate the frequency, expansion and colour of the waves.
Roland R. Kahlenberg
on Nov 16, 2011 at 3:59:40 pm
As Brian has suggested, Radio Waves will do a good job. Shape Layers are also worth a look into.
As for your perfect squares and circles, stay away from non-square PAR comps - it's really as simple as that. IOW, stay away from working in non-square PAR comps. All it does is to create lots of unwanted issues.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Michael Szalapski
on Nov 16, 2011 at 5:04:29 pm
However, if you must work with non-square pixel aspect ratio comps, make sure to toggle the pixel aspect ratio correction switch.
- The Great Szalam
Walter Soyka
on Nov 16, 2011 at 6:42:54 pm
[Michael Szalapski] "However, if you must work with non-square pixel aspect ratio comps, make sure to toggle the pixel aspect ratio correction switch."
Indeed. It's right below the comp viewer and it looks like this:
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
on Nov 16, 2011 at 6:55:22 pm
[Michael Szalapski] "if you must work with non-square pixel aspect ratio comps"
meh? I've never had a scenario where I've had to work within the confines of a non-square PAR comp. Even AI provides for only square-pixel PARs presets. Photoshop still allows for non-square PAR presets but I think that may go out of the window in due time.
Cheers
RoRK
Putopian vohra
on Nov 17, 2011 at 5:28:27 am
Thanks everyone.
It helped me very much.
Putopian
