Choke effect on an image
Danielle Masek
on Nov 16, 2011 at 5:42:55 am
I'm trying to take an imported silhouette and have its edges sort of go in on itself. Please see attached photo. How do I do this? I've tried choke but nothing happens.
**I look down at where you're standing
Flock of sheep all on display
With all your lies piled up around you
I can take it all away**
Brian Charles
Re: Choke effect on an image
on Nov 16, 2011 at 3:53:46 pm
You may be able to use the MiniMax filter set to Minimum and then ad a blur to it.
Roland R. Kahlenberg
on Nov 16, 2011 at 4:08:58 pm
By 'choke' I am assuming that you are alluding to Matte Choker or Simple Choker. These require a non-full screen alpha channel. If your image doesn't have an alpha channel, then you can create one using Shift Channels. I suggest that you search the COW for previous posts on how to create mattes from one of the color channels.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Danielle Masek
on Nov 16, 2011 at 11:06:12 pm
Well choke seemed like the best way to describe what I'm trying to do. It may not be right. If you can picture the image I posted as the full silhouette of a man w/out any fx. Then it transforms into that pic, which looks like the edges moving inward to me. If that's not what it is let me know what it is.
