changing the value on multiple key frames simultaneously
mike cantor
on Nov 15, 2011 at 4:06:47 pm
I have layer with about a hundred keyframes for "Scatter" in the CC Star Burst effect. I would like to lower all of the keyframes by a certain amount. Of course, selecting them all and then scrubbing the value down does not do the trick -- this just creates a new key-frame at the current position.
Is there anyway to change the value of multiple key-frames in an effect as a group?
Thanks a bunch,
-mike
Todd Kopriva
Re: changing the value on multiple key frames simultaneously
on Nov 15, 2011 at 5:00:20 pm
What you described should work: selecting multiple keyframes and dragging the property value. That is described here.
I prefer to manipulate multiple keyframes in the Graph Editor, as described here.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Roland R. Kahlenberg
on Nov 15, 2011 at 6:05:54 pm
What you want to do involves a 3-step procedure - you've missed the second step, which is to ensure that the TCI is parked on an existing KF.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Ryan Rosario
on Nov 18, 2012 at 10:23:37 pm
I am struggling the same way.. I did everything and it still didnt work..
