Anyway to use Warp-stabilizer to multiple clips at the same time?
Kazumi Hatori
on Nov 13, 2011 at 2:21:17 am
I wonder if any of you try to apply warp stabilizer to many clips at the same time(i.e. 50)?
It seems that all the effects run at the same time and then it hangs.
So I can now only adding the stabilizer one by one.
Anyway to let it render one by one by itself?
Todd Kopriva
Re: Anyway to use Warp-stabilizer to multiple clips at the same time?
on Nov 13, 2011 at 4:43:34 pm
No.
Also, the Warp Stabilizer is very demanding of both CPU power and RAM. So, if you have a computer with a slow CPU or little RAM, then you certainly don't want to try to feed the Warp Stabilizer a lot of clips at once (or long clips).
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
