Tricky Stabilization: actress with no background <-
Michele Poggi
on Nov 9, 2011 at 12:29:31 pm
Hey guys. ;)
Here we are, I have this tricky clip to stabilize.
The actress is -of course- alive so it's not easy to me to figure out what to do.
My best shot was to track her eyes, but it didn't turn out well.
I've uploaded the video for a better understanding, do you have any tip or idea?
As always, thanks. Let's see if we can find a solution for this one.
http://reels.creativecow.net/film/tricky-stabilization
"Freelance Post-Producer"
Editor Video
Graphic Designer
Digital Compositor
Mail: snm.poggi@gmail.com
Mobile: +39 3349129191
Skype: sabakunomaiku
steve agriosi
Re: Tricky Stabilization: actress with no background <-
on Nov 9, 2011 at 1:47:19 pm
i might need a tutorial on how to post video /or still on cow.
Is this a video or a photo still?
Your description makes me think that you may have to try the stabilize engine inside mocha
Use eyebrows instead eyes but keep untouched the first and ending frame
So you will have a smooth camera motion path.
But again if i can watch ur video i might be wrong.
Btw..i assume your door/shadows fx shot is completed right?
Roland R. Kahlenberg
on Nov 9, 2011 at 2:31:40 pm
This one is tricky cos you've got camera movement as well as movement from the subject. Also, there seems to be less movement from her eyes, hairline and nose - so perhaps those are good places to track.
If you have AE CS5.5, it will be interesting to see how the Warp Stabilizer handles this shot.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
steve agriosi
on Nov 9, 2011 at 2:46:25 pm
ok...i blame safari for windows!!!
your video appeared as still with no playback controls. On firefox works ok.
So..
i thing you should try mochas planar tracker
from 0 -12 sec try to track the shoulder behind book.
Then you can add a new spline on her dress chest to the 20 sec.
then candle and table can offer a final texture for a good tracking.
Use keyframes to smooth cameras path.
Looks easy..
Michele Poggi
on Nov 10, 2011 at 11:36:02 am
It indeed can be easy, it's that I'm still practicing Mocha, so using multiple splines is still something I have to test out. Same goes for the Warp Stabilizer. Thanks for the tips, I'll make sure to upload the result.
Editor Video
Graphic Designer
Digital Compositor
steve agriosi
on Nov 10, 2011 at 12:01:12 pm
hey
as Roland R. Kahlenberg already recommended try to fix it
using AE CS5.5 (warp stabilizer) I don't know if own this latest version.
I'm still on CS4 ...so if you are still practicing using mocha,
as an alternative those auto steady plugins such red giant stabilizer, or 2d3 steadymove.
It might be one click case...
Boris have a similar plugin but it's not my favorite!
Virtual dub does this steady miracle too..and it's free...but i assume you
dont wanna drop yourself into Virtual dub with deshaker plugin.
steve agriosi
on Nov 10, 2011 at 12:07:28 pm
FAST TYPING SIDE fx...
so let me add missing words ( bold )
hey
using AE CS5.5 (warp stabilizer) I don't know if you already own this latest version.
I'm still on CS4 ...so if you are still practicing using mocha, you may wanna try
Michele Poggi
on Nov 19, 2011 at 3:09:00 pm
In the end I found a way to avoid VirtualDub. I did indeed use it for all these years but most for converting and filtering with Avisynth.
Editor Video
Graphic Designer
Digital Compositor
steve agriosi
on Nov 19, 2011 at 3:50:18 pm
so what was the "healing" tool for you ?
