Greenscreen stop motion composition and render settings in After effects ???
kristina vasiljeva
on Nov 4, 2011 at 2:46:30 pm
I am fairly new to After Effects but have worked with premier pro before . I'm trying to make a stop motion animation using jpegs.(roughly less then 1 min long) Currently I'm using the HDV 1080 29.97 preset.
The idea is that a video file will be greenscreened behind the sequence for the sky effect of jpegs.
I am using keylight (1.2)for the greenscreen. What is the best way of creating and rendering the project?
Do i have to render each jpeg after i set the keylight then return and put it together with the avi in the background as it has not worked when i try to set it up all together and render right away. Is there any other render settings i should use, so far i'v been using the video for windows format choosing the RGB+Alpha output.
Michael Szalapski
Re: Greenscreen stop motion composition and render settings in After effects ???
on Nov 4, 2011 at 3:09:10 pm
Why not import all your pictures into AE as an image sequence? Then you can just treat is as a video. Make sure to interpret the footage at the correct frame rate. Then you can just treat it as a video file when you're doing your keying.
- The Great Szalam
Walter Soyka
on Nov 4, 2011 at 3:55:06 pm
I agree with Michael -- image sequences will work well for your JPEGs.
I'll also add that the HDV 1080 29.97 preset doesn't use square pixels. Unless you have a specific reason to use that, you might want to use the HDTV 1080 29.97 preset instead.
I'd also do all the compositing in AE, rather than rendering out a movie with an alpha channel and compositing in Premiere.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
