string of objects to follow a psuedo Bezier
Juan Hernandez
on Oct 31, 2011 at 7:30:53 pm
Hi all,
I am having a touch of a hard time figuring out Dan's awesome tutorial:
http://www.motionscript.com/expressions-lab-ae65/bezier.html
I am trying to pull this off only the test scenes of the solids are not following nulls as I imagined. Has anyone did this before where they might want to share their AE scene for me dissect?
What I did was made a solid and under the position, I pasted the expressions Dan shared.
Nothing happened as mentioned in the tutorial and no immediate gratification was established once I pasted the expression as instructed.
Thanks for any who help out.
-J.
Juan Hernandez
Re: string of objects to follow a psuedo Bezier
on Oct 31, 2011 at 8:32:27 pm
Okay I think I got it...but I'd like to get help with the slider bit of the tutorial...THIS IS SUCH A COOL SETUP!
THank you DAN!
And thanks for those that help in response.
J.
Juan Hernandez
on Oct 31, 2011 at 9:42:35 pm
THank you DAN!
And thanks for those that help.
Dan Ebberts
on Oct 31, 2011 at 11:10:55 pm
What do you need help with?
Dan
Brian Charles
on Oct 31, 2011 at 11:12:40 pm
After adding the slider expression control to Null 1 the modification the script should read:
N1 = thisComp.layer("Null 1");
N2 = thisComp.layer("Null 2");
N3 = thisComp.layer("Null 3");
N4 = thisComp.layer("Null 4");
p0 = N1.position;
p1 = N2.toWorld(N2.anchorPoint);
p2 = N3.toWorld(N3.anchorPoint);
p3 = N4.position;
c = 3*(p1 - p0);
b = 3*(p2 - p1) - c;
a = p3 - p0 - c - b;
t0 = index/(thisComp.numLayers - 3);
s = N1.effect("Slider Control").param("Slider");
if(s < 0){
s += 1;
t = t0*s;
}else{
t = s + t0 - s*t0;
}((a*t +b )*t + c)*t + p0
