paint background object
Kevin Allar
on Oct 29, 2011 at 6:37:12 pm
I have a locked down shot of people getting into a car. How do I "re-paint" the color of the car?
Kevin Allar
Angelo Lorenzo
Re: paint background object
on Oct 29, 2011 at 7:58:14 pm
This is a very complicated situation. First, we would need to know the color the car is currently along with the color you would like the car to be. The reason being is that it's much easier to do a hue shift from, say, red to orange or blue to purple than it is to change color straight out from black to red for instance.
Let's say that you want to change the color of the car from yellow to green but a shade of green that is relatively the same luminosity but not in the same hue family, like electric green.
1. Create a new solid layer with the color you want the car to be more or less.
2. Mask this new layer to fit the outline of the car.
3. Set the blend mode to color. You'll notice that this probably get you 75% of the way there.
4. Copy your original video layer above your current two layers, add the mask and change blending mode to saturation. This will help pull the reigns in on the color and desaturate the shadows for a more true-to-life look.
5. Create an adjustment layer and copy the mask from the solid layer to the adjustment layer. Add an HLS and curves adjustment. Chances are it'll need to be tweaked further.
This is probably one of the easier ways of doing a color change that looks good.
Roland R. Kahlenberg
on Oct 30, 2011 at 3:37:39 am
Lots of ways to do this and Lorenzo has already provided one - it all depends on the source footage. If you embed the footage together with your post, it'll allow more folks to more easily assist you.
Cheers
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Tudor "Ted" Jelescu
on Oct 30, 2011 at 12:20:49 pm
I agree that having the footage will get you more input.
Of the top of my head, without seeing it, I would say that if you have a clean plate (or if you can create one), you can pull a difference key to get a mask for the people getting in the car and use PSD to create a plate where the car has the color you want. Cut the car out of that, composite behind the people getting in the car, and match grain.
Tudor "Ted" Jelescu
Senior VFX Artist
Michael Szalapski
on Oct 31, 2011 at 1:32:51 pm
An alternate solution (as there are many) would be to apply Hue/Saturation to your layer. Change the channel from master to one of the channels that most closely represents your car's color. Swing the hue to make the car more the color you want. Tweak the paremeters of the color channel to get it narrowed down to your car's color.
- The Great Szalam
