GPS data graphic overlay from external file
Scott Manley
on Oct 26, 2011 at 1:22:11 am
Hello,
I was wondering if anyone had had experience loading data from an external XML, TXT, or CSV to show a graphic representation of speed, lat/long, etc from a GPS device via the custom scripts panel?
I was able to export the GPS data from the new contour+ and wanted to make speedometer and elevation overlays for the video.
In the contour storyteller software there is an option to export GPX cross platform GPS data. I was able to add a .TXT to the end of the GPX file and found out its an XML document.
Also I can export CSV data from the storyteller software, but I think it truncates the Lat/Long data to 2 decimal points.
Can anyone please help me?
Thanks for your time.
Roland R. Kahlenberg
Re: GPS data graphic overlay from external file
on Oct 26, 2011 at 6:13:11 am
This definitely requires a script. Perhaps the COW's Expression Forum is a better place for your Q. Additionally, http://www.aescripts.com is another place you should visit.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Scott Manley
on Oct 26, 2011 at 6:17:59 am
Hi Roland,
I will check out that section, thank you.
I have started a question over at aescripts already with no response, yet.
-Scott
Scott Manley
on Oct 26, 2011 at 4:17:14 pm
Hi Todd,
Thank you for pointing me in the right direction. I really appreciate it.
I'll do some digging and see what the next step will be.
-Scott
