Rendering : Media Encoder and purging every frame??
Tristan Summers
on Oct 25, 2011 at 11:04:39 am
If anyone has any tips on yhis it would help a lot...
SOOOOO.
I am rendering with ACCURATE anti-aliasing on Vector files.
This causes rendering to crash if I do not purge every frame.
IF
I want to render in background using Media Encoder,
CAN
I get IT to purge every frame also?
Does it follow the project settings?
Or is this a different preference in Media Encoder?
Tris
Roland R. Kahlenberg
Re: Rendering : Media Encoder and purging every frame??
on Oct 25, 2011 at 2:10:06 pm
Hi Tristan, it sounds like you're not on a 64-bit version of AE, where AE's 32-bit versions may occasionally require a Purge every Frame setting upon rendering to get your timeline rendered.
I doubt that AME has such a setting. It sounds like you're loading your comp directly into AME. It looks like you'll want to render out directly from AE, to a high-quality file and then feed this file into AME.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
