Mocha troubles!!! Cant see video.
Jorge Rosado
on Oct 17, 2011 at 3:38:26 am
I'm trying to do some tracking in Mocha for AFX which I've done before but for some reason now when I import my footage I cant see the image. Here's a screen shot of the problem.
Thanks in advance!
Roland R. Kahlenberg
Re: Mocha troubles!!! Cant see video.
on Oct 17, 2011 at 8:32:19 am
Try another video and if that works then take a look at the CODEC used for the problem footage. Then take the necessary action.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia.
Sean Mullen
on Oct 17, 2011 at 3:10:46 pm
Hi Jorge,
I've run in to this in the past. If you are using After Effects CS4, it seems that the version of Mocha that comes bundled with it doesn't like certain codecs like ProRes. I've had good luck with converting to the Animation codec - just for tracking purposes.
Sean Mullen
Rampant Design Tools
Jorge Rosado
on Oct 17, 2011 at 4:21:08 pm
Thanks! Changing the codec worked!
