Looking for tutorial for diamond sparkle text animation
Ditha Angraini
on Oct 14, 2011 at 2:33:16 am
I'm looking for After Effect tutorial on how to make something similar to this:
http://www.istockphoto.com/stock-video-14951949-2011.php?st=66449ad
If you know how to do it or know of a tutorial could you please let me know? Thank you very much :)
- D
to learn the true meaning of victory, go and ask the defeated warrior
Tudor "Ted" Jelescu
Re: Looking for tutorial for diamond sparkle text animation
on Oct 14, 2011 at 7:00:24 am
One way of doing this would be to create a looping animation of one diamond with a lens flare applied on top and animated to create the "sparkle". Once you have that you can precompose and duplicate that comp as many times as you need to create a texture for the face of the letters/numbers. If you need just 3d looking text with no camera move, you can create the text in AI or PSD, import it in AE, and build the face of the letters using the diamond texture. If you need volumetric letters that will react to camera moves I recommend looking into ShapeShifter AE or Zaxwerks Invigorator Pro. You can then create the depth of the text using those plugins and match the position behind a 3d layer that has the same text build out of the diamond texture.
Tudor "Ted" Jelescu
Senior VFX Artist
Ditha Angraini
on Oct 19, 2011 at 8:40:52 pm
Thank you for the suggestion, will try it :)
Walter Soyka
on Oct 14, 2011 at 5:41:00 pm
A different suggestion for a slightly different look: you could use a wall of lights [link].
Tweaking the lens flares and laying them over a diamond texture would get you back closer to the diamond look shown here.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Ditha Angraini
on Oct 19, 2011 at 8:41:00 pm
Thank you very much. I'll give it a go and see how it goes :)
