Burning in timecode and filename for dailies
Angelo Lorenzo
on Oct 13, 2011 at 1:03:49 am
I've seen this asked before in this and the Premiere forum since there is no mechanism to burn in both timecode and the filename into dailies for clients. I wrote a little After Effects expression for those who burn all their dailies in one continuous video.
1. Import all your footage.
2. Select all of your footage in your bin and drag it onto the New Comp icon.
3. Select "Sequence Layers" with overlap turned off. This will layout each piece of video one after the other.
4. Create a new blank text layer as layer #1
5. Add this expression to the text layer's "Source Text":
for(i=2;i<=thisComp.numLayers;i++){
if(thisComp.layer(i).inPoint <= time && thisComp.layer(i).outPoint >= time){
text.sourceText = thisComp.layer(i).name +" -- "+ timeToCurrentFormat(thisComp.layer(i).sourceTime());
6. Adjust the size, position and color of your text layer to taste.
7. Render out and send to your client.
I'd suggest saving this as an expression effect that you can drag onto text layers as needed.
- Angelo Lorenzo
- http://FilmsFor.Us Sell your film and connect with your audience
Roland R. Kahlenberg
Re: Burning in timecode and filename for dailies
on Oct 15, 2011 at 12:51:24 am
Thanks for sharing this Angelo.
Cheers
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia.
Frederic Lumiere
on Oct 30, 2012 at 12:47:13 pm
Brilliant.
Thank you!
