Generating grids
Alfred Hammer
Generating grids
on Sep 29, 2011 at 8:19:14 am
I'd like to generate a grid inside of a custom shape. I tried creating a new solid, asking it and then generating a grid, but the grid applies on to the entire solid. I also tried making a shape layer and then generating a grid inside of it, but no luck. Is there a way I can go about doing this?
Thanks in advance.
Alfred Hammer
Re: Generating grids
on Sep 29, 2011 at 8:26:58 am
Something like 0:30 of this video.
Brian Charles
on Sep 29, 2011 at 12:47:20 pm
Have you tried to distort the grid using Mesh Warp over the grid layer?
Alfred Hammer
on Sep 29, 2011 at 1:51:27 pm
Just tried, doesnt seem to work
Alfred Hammer
on Sep 29, 2011 at 1:53:52 pm
I just tried the using the eraser tool, takes a lot of time... but hey, atleast it works. If you do know another workaround, I'd be grateful
Roland R. Kahlenberg
on Sep 29, 2011 at 4:04:38 pm
Brian's suggestion WORKS! You've quite obviously have it all backasswards. In fact, the FreeFormAE plugin that is bundled with AE should also do the trick f you require 3D deformations of your grid.
If the grid is offending your vision, after applying the Mesh Warp then you should temporarily switch off the Grid effect as you manipulate the appropriate points to their destination.
Cheers
RoRK
Intensive AE & Mocha Training in Asia.
Walter Soyka
on Sep 29, 2011 at 2:31:57 pm
[Alfred Hammer] "I'd like to generate a grid inside of a custom shape. I tried creating a new solid, asking it and then generating a grid, but the grid applies on to the entire solid."
From Render order and collapsing transformations [link]:
Note: Some effects ignore masks on the layer to which they’re applied. To have such an effect operate on a masked layer, pre-compose the layer with the mask applied, and then apply the effect to the pre-composed layer. (See About precomposing and nesting [link].)
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Alfred Hammer
on Sep 30, 2011 at 3:12:05 am
Got it! Thanks a bunch guys.
Alfred Hammer
on Sep 30, 2011 at 9:34:15 am
I tried pre composing and then applying the effect, but that doesnt seem to work, what am I doing wrong? I've uploaded the screenies.
Without the effect applied
With the effect applied
on Sep 30, 2011 at 11:13:06 am
Can we just forget about mask shapes for this one? It isn't required at all.
All you need to do is to create a solid at the size that you want. Then apply the Grid effect followed by FreeFormAE or Meshwarp and distort accordingly.
HTH
RoRK
Eric Santiago
on Sep 30, 2011 at 5:51:45 pm
Just as Roland suggested this is best unless you have access to 3D software.
Alfred Hammer
on Oct 1, 2011 at 2:31:45 am
Unless Im doing something wrong.... mesh wrap doesnt seem to work.... all I can achieve is this.
Walter Soyka
on Oct 1, 2011 at 3:11:12 am
The grid effect needs to be applied to the solid within the precomp, not to the precomp itself.
The precomp (which will be a rectangular grid) should then be masked to whatever shape you like.
Walter Soyka
