Reverse stacking order of masks, how?
Göran Thorén
on Sep 26, 2011 at 9:10:45 am
Hi!
As for now I have a couple of hundred masks that I have copied from Illustrator paths. I'm going to apply the stroke effect and I need the stacking order of the mask to be reverse to get them to stroke in the direction I want.
Anyone know a fast way to do that?
Thank's inadvance.
/Göran
Roland R. Kahlenberg
Re: Reverse stacking order of masks, how?
on Sep 26, 2011 at 3:26:53 pm
You can set the Stroke's Start and End properties to 100%. Then keyframe the Start property down to zero.
HTH
RoRK
Intensive AE & Mocha Training in Asia.
Göran Thorén
on Sep 26, 2011 at 4:54:26 pm
Thank's Roland but that isn't really the problem.
The problem is that I need the stacking order to be reversed so sequence stroke gets right.
on Sep 26, 2011 at 5:28:33 pm
Doing what I suggested reverses the order in which the masks are stroked. No?
RoRK
Göran Thorén
on Sep 26, 2011 at 5:42:28 pm
Yes and no.
It reverses the direction each mask is drawn but not the ORDER the masks are being drawn.
In my case I have almost 300 masks (which I now have manually reversed the order on) where the first mask is located on the bottom of my comp. the second mask a bit further up, the third even further up and so on.
What I need is to reverse the order of the masks to get the opposite result; from top to bottom.
I guess it's a bit tricky to wrap ones head around the problem when you can't see the actual comp... ;)
on Sep 26, 2011 at 6:19:47 pm
So, You have your masks stacked up in the Timeline, from the top as follows -
Mask 1
Mask 2
Mask 3
Mask 4
Mask 5
And you now want to reorder it as such -
Mask 5
Mask 4
Mask 3
Mask 2
Mask 1
Is this correct?
What you can do is use the Layer>Arrange>Send Mask to Back menu item. Select the second to last mask (Mask 4 as per the example above) and hit the Short-cut key CTRL+SHIFT+[ . Then select the next mask further up the hierarchy. Once you get to the top, the last mask will now be ordered first.
It's a bit tedious but if you combine your mouse to select the masks and use your other hand for the key combo, it'll be a pretty quick exercise.
Unfortunately I don't know of a way to reverse the order at one go, like you can with layer orders.
HTH
RoRK
Göran Thorén
on Sep 26, 2011 at 6:29:05 pm
Wow, thank's Roland!
That's a really handy trick!
I've used AE for allmost ten years but I have never came across that.
Or maby it's not every day you have hundreds of masks that need reordering... :)
I thought the old "select from bottom cut'n paste" would do the trick but not when it comes to maskes unfortunately.
After effects do seem to have a couple of things to develop still...
Thank's a million anyway Roland!
/Göran
on Sep 26, 2011 at 7:05:23 pm
You're most welcome Göran.
Cheers
RoRK
Harold Durnez
on Dec 27, 2013 at 7:45:23 pm
Hi Göran & RoRK
I'm in the same predicament...
Have you guys come across an easier solution since?
(Definitely a suggestion for a script)
Hope to hear from you soon.
H
Harold JM Durnez
harold.durnez@gmail.com
http://www.behance.net/HaroldDurnez
http://vimeo.com/channels/harolddurnez
Davy Force
on Jan 14, 2014 at 7:33:23 pm
FOUND AN EASY WAY FOR THIS FOLKS!!
Select bottom mask first (mask 100 or whatever) then multiselect (shift) the first mask (mask 1) so youve multiselected in a reverse order. CUT the selection (to delete paths) then paste back into same layer- Mask later order will now be reversed-
your welcome!
Harold Durnez
on Jan 21, 2014 at 9:21:35 am
NO WAY! haha so simple.
- Thanks man !
Harold JM Durnez
Alexander Roberts
on Jan 28, 2014 at 1:08:56 am
So this is what I tried to being with, since if works likes this with layers. But for whatever reason I they paste back in the same order not reversed. It doesn't matter if I select the top or bottom one first, still pasting back in the same order. I tried adding a mask path keyframe to see if that would change it. Any ideas on why it's not reversing mask order for me?
Alex
