AFX not showing immediate changes
Adam Duplay
on Sep 19, 2011 at 11:56:47 pm
I must have changed something inadvertently...
Now when I adjust a parameter I don't see the change as I am moving the mouse, only when I stop moving.
For example... make a new mask then use the mouse to adjust the mask expansion parameter. It used to be the case that I could see immediate feedback and see the mask outline change as I adjust the slider. Now the change only becomes apparent when I let go of the mouse. The same issue is affection all parameters... position, scale, etc.
Thanks in advance.
Adam Duplay
Travis Fadler
Re: AFX not showing immediate changes
on Sep 20, 2011 at 12:17:26 am
Check your fast preview settings and try adaptive resolution or different OpenGL settings. It's the lightning bolt tab at the bottom of your comp.
Brian Charles
on Sep 20, 2011 at 12:32:24 am
Check your "Live Update" switch.
http://help.adobe.com/en_US/aftereffects/cs/using/WSAF696587-2D81-42e2-B248...
Adam Duplay
on Sep 20, 2011 at 3:26:58 pm
Thank you. It was the Live Update Switch.
Adam Duplay
