Adding expressions to Mask Shape property's keyframes (AE7)
Eric Chard
on Sep 16, 2011 at 9:20:44 pm
using
loopOut(type="cycle",numKeyframes=0)
I easily looped the keyframes of a test layer's opacity.
Unfortunately, I want to loop the keyframes of a layer's Mask Shape. But when I select the property and attempt to use "Add Expression", it's greyed out (not available).
This is aggravating, 'cuz I don't want to do anything fancy with the shape per se, I just want it to loop.
Is there any way around this in AE7?
Thanks.
"Putting the HARM in 'harmonica' since 2005."
Roland R. Kahlenberg
Re: Adding expressions to Mask Shape property's keyframes (AE7)
on Sep 17, 2011 at 1:56:33 am
The Mask SHape property doesn't allow for Expressions. Your workaround is the precomp the layer, apply Time Remapping, apply the required KFs to the Time Remapping property and then apply your loop Expression. You will want to create temporary Comp Markers prior to precomposing so that you know where to place the Time Remapping KFs.
HTH
RoRK
Intensive AE & Mocha Training in Asia.
Todd Kopriva
on Sep 17, 2011 at 3:11:03 am
That's true for the version that Eric has, but not true in the current version of After Effects.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
on Sep 17, 2011 at 4:04:30 am
YUP! I think this feature was added in AE9.
Cheers
RoRK
